33-34 Front Radius Rods are shorter then 32.
33-34 Torque Tube and Drive Shaft are longer then 32.
32 parts are getting very hard to find.
Rear Track (width) is the same as Late 32.
Front track is the same.
Chris
Will work except DS and torque tube which are a different length on 32 because of 106 wb. Radius rods mount different on a 34 and may have to be shortened. What is wrong with the present rear end you have. If it is a late 32, you can swap the torque tube and DS, early is made like a Model A with a solid DS.
