Bob Johnson
Today I recorded the radiator temperature while the car was stationary with the engine running at idle speed. The engine was completely warmed up. The outsize temperature was 68 F. I took readings for about 12 minutes. Twice I stepped on the accelerator for about 5 seconds to see what would happen to the temperature if I increased the engine speed. The first on was just after the 4 minute mark and the second one was right at the end. Currently I have a 160 degree thermostat installed just above the goose neck at above the head. The thermostat has one bypass hole about 3/16" in diameter.
Bob
Bob
