Brian in Wheeling Senior Member Mar 21, 2017 #1 O.K. Please help and identify these carbs for me. I will then move over to the swap section, if there is any interest. Thanks Fordbarners! Brian Attachments IMG_1087.jpg 40.1 KB · Views: 246 IMG_1088.jpg 35.4 KB · Views: 202 IMG_1091.jpg 75.4 KB · Views: 218
mantta Senior Member Mar 21, 2017 #2 The top two are tillotsen. The bottom one, if it is aluminum is tillotesn also.
TinCup Well-known member Mar 21, 2017 #3 Top left Tillotson Top right Tillotson Model XF sold by Ford Bottom Simmons Zenith look alike but with improvements including accelerator pump.
Ron in Quincy Well-known member Mar 21, 2017 #4 The top two are the common Tillotson replacement after market. The bottom one is the first Tillotson after market made , it is called the F1B.
B Bob C Well-known member Mar 21, 2017 #6 I don't think the bottom one is a Tillotson. Bob Attachments Tilly.jpg 46.3 KB · Views: 56 Tilly-not.jpeg 75.4 KB · Views: 71
Flathead Well-known member Mar 21, 2017 #7 Bottom one is a Simmons as previously stated. Looks similar to the F1B but is a Simmons. The drain plug on fuel bowl is good way to tell.
TinCup Well-known member Mar 22, 2017 #8 F1B is very different than the Simmons. The F1B is pot metal and the Simmons is cast.
Flathead Well-known member Mar 22, 2017 #9 The Simmons was made in pot metal and also cast iron, I have examples of both.
R Richard Lorenz Senior Member Mar 22, 2017 #10 The bottom carburetor is definitely the pot-metal Simmons. I also own a cast-iron Simmons, and a cast-iron Simmons that was made for a stationary use (GAV plugged up and a place for a remote throttle control).
J jhowes Well-known member Mar 22, 2017 #11 The bottom one is a Tilly F1B. It says Tillotson right on the fuel bowl. Jack
Tom Wesenberg Well-known member Mar 22, 2017 #12 jhowes said: The bottom one is a Tilly F1B. It says Tillotson right on the fuel bowl. Jack Click to expand... It does in Bob C's first picture, but not his second picture nor the bottom picture in #1.
Ron in Quincy Well-known member Mar 22, 2017 #13 I was in error when I said the bottom carb was a F1B, it is a pot metal Simmons. Ron
Joop Well-known member Mar 22, 2017 #14 This may help! Potmetal Simmons .. Attachments IMG_3970.jpg 101.4 KB · Views: 42 Last edited: Mar 23, 2017
