I finally found it, it was under 1932 Ford Headlites, you wouldnt find it that easy if you searched 1932 headlights. the id # is 280630984900. I took a hard look at them and by gosh they are factory 32 originals. I have not seen a pair so clean come up for sale like those in a long while. You can still clearly read FORDTWOLITEHEADLAMPS on the reflector.
Your lucky I dont need them. If I were you I would still consider the repos, you get all the hardware. Good luck
