On my 36 Ford 2 dr. sedan, I have 2 windows that when rolled up will not move forward the last inch to close the window completely. I decided to remove the window garnish molding and door panel upholstery to see if I could find out what was causing the windows from moving forward the last inch. On the passenger side door, after removing all the screws that hold the garnish molding in place, I thought the garnish molding would just come out, not so, the molding is loose but will not come out, I have pushed, pulled and wiggeled it every which way, but it will not come out, when I try to pull it straight out, it is hitting some metal brackets ( makes a metalic sound ). I can't see inside the door frame very good, but am thinking the molding is contacting the brackets the molding screws go into. Can anyone explain to me what is stopping the molding from coming out or the procedure to rmove the garnish moldings.
Thanks Glenn
Thanks Glenn
