I heated mine in the gas grill set to 500 F.
Just did this for my Burtz flywheel. I put the flywheel overnight in the freezer and used the gas grill set to max to heat the ring gear. I put three 2x2x3/8” (dimensions not important, those are what I had) steel flat bar pieces on the gas grill, and set the ring gear on them to keep grill scudge from getting on the ring gear. I heated the ring gear and monitored the temp using a cheap IR thermometer I got from the River Store. Gear needed to be 450F or above, it will be slower to heat where it touches the standoffs. Be prepared with a brass drift and a big hammer (or an air hammer) to seat the ring gear once you get it started. Oven mitts are your friends.
Better to have the gear too hot than not hot enough. If you get it partially on and can’t finish you’re screwed. Either use a torch to heat up the gear or cut it off.
Remember that for a standard Model A starter motor (even with a “modern” Bendix assembly) that the bevels on the ring gear teeth face aft (towards the clutch surface).
Oldford, I think an electric oven would work fine, you might have to use the broiler to get it hot enough. Those IR thermometers are pretty handy, they can be had for well less than $50. I’ve used our electric oven to heat up bearings (e.g, ring gear carrier). Like 400A says, do it when your spousal unit is not around to object, and turn on the range fan. And always act innocent.
Back in the “old days” the guys who made wagon wheels used a ring of fire to heat up the steel bands that went onto wooden wagon wheels. Lots of YouTube videos out there, it’s a fascinating process.
