Not being a smart ***, but how?
I mean like stropping a razor to sharpen it is in the opposite direction of cutting.
A knife is sharpened running the cutting edge forward on the stone, on both sides, to a point that will be an edge as thin as you can get it. I normally use diamond blocks. From there you use a steel, to remove the wire edge, which is the remnant, that the stone couldn't clean up. You can easily shave with a well sharpened knife. A straight razor on the other hand is hollow ground on both sides, as some knifes are, and when they get a nick in the blade, they also have to be stoned, but not as aggressive as you would a knife, also on a very fine stone. Now as long as the edge of the razor is thin, with out nicks, you use the leather strap to touch up the edge, and as Mr. 4 says pulling it backwards, on one, side, and then the other. ((( Besides, If you went the other way, you would have to many small pieces of strap to work with))) This really doesn't remove metal like a stone, but it does keep the edge straight, and thin, and not laid over. The reamer is another story. The best reamers, are the spiral fluted, rather then the straight fluted. The spiral is made that way, to give less chatter, I normally use cutting oil, unless there is a problem with getting rid of the chips, with the oil. Now, NEVER TURN A REAMER BACKWARDS, as the reamer cuts in ONE direction ONLY. The cutting edge is relieved with a 45 degree angle, so your cutting edge is the first point on the flute that touches when it is sharp. If you turn the cutting edge backwards, the cutting edge will role over, and look like a sled runner, and as you try to cut again, the cutting edge is now below the point of contact, and IT DON"T TAKE MUCH. When your cutting edge wears, the cutting edge gets wider, and starts to get dull, if you let the reamer go to long without sharping, you can not bring the reamer back to spc,s. They can normally be touched up about 2- 4 times, if you don't let them go to long. If you are having trouble with the bushings moving, or not staying tight, use sleeve retainer, or make your own, with larger O.D.'s. All brass, or bronze bushings are fit with a .002 thousands press, NOT OIL LITE BUSHINGS, Now, the sunnen hones work very well, as you always have control on the size you want, No bind, and no other movement. thanks Herm.
