rons49
I have a slight seepage of fluid in my front driver side shock. I am presuming that the O ring seal is bad. However when I removed the shock, I discovered that the unit has the following embossed around the square nut: "Hydraulic Shock Absorber Made in Chicago Ill." Below the filler plug Ford ( in script) is also embossed. No where does Houdaille appear. Are these shocks reproductions ? Can they be rebuilt, and resealed? The reservoir cover also appears to be one piece, although there is what appears to be a phony seam where the lock ring abuts the cover. The spanner wrench holes are in the " lock ring" 180 degrees apart. The shock really operates well, with nice resistance up and a bit more on the down stroke. Does anyone have info on these? Ron
