That reminds me of when I was a young guy fixing my lawn mower. So you mentioned the scavenging effect. That's a real science in two-stroke racing engines. So I thought I would push the limit on a four-stroke.
So I decided to make a race car. I milled the head off till there was nothing left but the valve chamber. Then I had to bore it deeper to make room for the valves to lift 'cause I didn't put a gasket it back on it either--I just glued the head on with coppercoat.
As for the cam shaft, I just ground it on a regular bench grinder and welded the lifters longer so I could adjust it. I made the exhaust open well before the piston was all the way down from the power stroke and didn't close it until it was starting back down on the fuel intake, then it would drop, with lots of valve overlap. Then I put a 21-in. half-inch straight pipe on it for the exhaust. When you finally got that thing started, you couldn't stop it! You could mow as tall and wet and as heavy a grass as you ever saw and it would just grind it up. I mean literally RUN through the yard, trying to bog it down. I tried and tried to just blow that thing up. Couldn't do it. It got to where it smoked pretty bad. I called it Thumper!
You know, that scavenging effect thing works pretty good.
But you gotta have it revved to the nuts to work! Once it gets there, it's like a rocket!
