Can't be done!I think I read to much
When someone tells me I can't
That becomes a challenge in my world
The problem is
You can't believe everything you read but weed thru it and pick the subject apart look at the situation twist the head around a couple times and if i do this will it work or just go for it
The problem is
So what is a safe steady speed for the engine mph with 3.27 rear end, burlington crank,
with inserts and rods from antiqueengines, 6.0 head, stipes cam, pistons with plenty of clearance and a pair of heavy boots and a tank of gas!
What is a safe rpm range, something in the realm of "normal" for this engine
pretty please ?
What is a safe rpm range, something in the realm of "normal"for this engine
30 tudor
Thats a good???
I would like to know that also
Wich all depends on the tire size also
With what I've read 31 inch tall tire 70mph 327 gear is about 2400 but I've read that it about 80 horse to do it with all aero dinamics of a model a
Those are more or less the numbers I achieved on Pendine Sands in the 29 CCPU in my avatar - B engine with an ali Winfield head, SU1R cam, single 97 and Mallory distributor (actually 69.87mph @ 2411rpm) with a 3.27 rear end on 21"s. It will go faster on tarmac, but not by much.
Really doubt it's making 80hp though.
There's a formula somewhere for calculating power from measured speed/gearing/frontal area. I'll go look it out if somebody will tell me the frontal area of a 29 CCPU![]()
Pardon me , but why wreck an antique engine beyond what it was never intended to be? You'll only shorten it's life. There are plenty of 4cyl, ohv, 100 hp engines available in the boneyards. Throw in a 4 or 5 spd and you'll have what you want. I saw one in so Jersey with a Volvo 4 cyl. I don't know how it ran, but it was a nice, clean installation.
Terry
