headonz
I have removed the old horn rod from the steering shaft to discover the bottom 1/2 is missing so have a replacement that needs a new horn wire installed.What is the secret in removing the horn button without destroying it ?
I have bent out the tabs on the underside and tapped gently on them to drive then backwards but nothing is moving ?
