redmodelt
I read my owners manual, push down turn counterclockwise, ok but no go. It only goes down so far and only twist so far but not enough for it to pop out.
I can only turn it about 3/8 to 1/2 inch. One side does stick up above the wheel higher then the other ruffly 1/8" compared to 1/16 inch. I don't want to pry on it and mess it up if I can help it. Any ideas, I need to replace the missing in action horn wire.
I wondered what that wire was for that is just hanging there with a connector on it, touched it to one of the generator studs, found out my horn works!
