Hood stays/ supports
Yes, just remove one at a time and slide them on.
I see I'm not the only one that bought a set while they were on sale...
I'll post a pic when I get mine installed unless someone else beats me to it
In the front, at the radiator, mark the positions of the nuts so that they go back is the same location. On my car I just loosen one nut on each rod and remember which nut I loosened. Not sure if the nuts can remain on when putting on the stays.
You are correct, the nuts have to be removed. That is why I said to remove one at a time.
I suggest you glue the black protectors on also. they come off easily. I used 'The Right Stuff'.
