Hello all,
1925 coupe, where the double tab hood latches clamp the hood closed, the round bead at the bottom of the side panels, the spring loaded latches appear to have worn through the bead. I'm wondering if I should weld up the worn hole? It appears that the latch gets a better clamp with the tab catching the hole.
If I restore the bead the clamp looks like it would slip off the side panel. Question is, is there suppose to be a tab hole there and it's not worn at all?
Thanks...
Thanks...
