Admiral
Hey guys,
Maybe this is old news but here’s an idea for a cheap and relatively easy way to make a spring spreader. All it takes is some 1-inch black pipe (24-inches long), a couple end caps, a bit of ½-by-20 running stock and some steel blocks. Here's what my concoction of iron looks like:
Just tighten the nut down on either side and the spreader gets wider. Loosen them to make it shorter. The hardest part is machining the end blocks that match up with the eyes of the spring, but you could just bring them to a point and fit them above the curved portion of the eye if you wanted.
The gray PVC cylinders on the ends of the running stock are to keep them from flopping around. They're machined to fit neatly inside the black pipe. I've also made some safety blocks that bolt around the spring so when I remove the U-bolts and/or the center bolt there are no unwanted surprises... and by that I mean exploding spring leaves!
