bugsiegel
See that red spring and its assembly? It pushes the lever below and that pumps/squirts fuel. You guys know this better than I do, why am I explaining this to you?
I was changing my jets today and discovered this thing. I think the tighter the nut on top the higher the pump arm will be allowed to come up resulting in a larger quantity of fuel to be pumped when pushed down. If that is correct, what are the ill effects of too much squirt vrs too little squirt?
Thanks Much
Paul
Thanks Much
Paul
