RonC Well-known member Jun 29, 2014 #1 Does anyone know if this hole in the rear main cap is a defect or purposely drilled oil hole? Attachments image.jpg 59.4 KB · Views: 135
Kurt in NJ Well-known member Jun 29, 2014 #2 If it doesn't go through to the oil passage it is probably a defect, if it is drilled through it is an attempt at stopping a rear main leak by draining it's oil supply Even if it is a "defect" it won't matter much if the rest of the babbitt is good
T tbirdtbird BANNED Jun 29, 2014 #3 babbitt doesn't look solid all the way down to the cap...looks hollow why is the pan down and the caps off? Last edited: Jun 29, 2014
K Kohnke Rebabbitting Well-known member Jun 29, 2014 #4 tbirdtbird said: babbitt doesn't look solid all the down to the cap...looks hollow why is the pan down and the caps off? Click to expand... Your right Mr. Tbird, you can see at the hole, and along both sides it wasn't Peened. Herm.
