Hole in rear main cap
RonC
Does anyone know if this hole in the rear main cap is a defect or purposely drilled oil hole?
If it doesn't go through to the oil passage it is probably a defect, if it is drilled through it is an attempt at stopping a rear main leak by draining it's oil supply
Even if it is a "defect" it won't matter much if the rest of the babbitt is good
babbitt doesn't look solid all the way down to the cap...looks hollow
why is the pan down and the caps off?
