High compression engine life.
kimlinh
I am still running a stock head. I'm sure the high compression heads run better, more power, cleaner burning, etc. However that also means more load on the bearings. With a stock oil system (not pressurized), I did not want to add more load to the bearings. Am I wrong? Are you guys with the 5.5 and 6 to 1 heads noticing shorter bearing life or any other related problems?
This question comes up frequently. I've never seen anyone link 6:1 heads to premature bearing failure. When you get up to 7:1 or 8:1, that's where folks start to recommend pressurized oil or stronger bearings.
Same here no problems!
Even if it lead to shorter bearing life, i wouldn't hesitate to use the 6.1 head. The contribution to better drivability in today's traffic is impressive. It's like my "A" is much happier!
've been running a 5'9 compression head for 23 years on our black 31 standard coupe with no problems . I did install a set of rebabbited connecting rods when the engine was overhauled prior to the installation of this higher compression head .
It's not so much the compression as it is running with too much spark advance with the extra compression. The over advanced timing causes detonation and that's what hammers out the bearing material. Babbit and insert both will suffer the same fate.
What Phil Brown says is right on! I run B blocks with C cranks, and have 2 that are all babbitt and stock oiling, both have been run in my speedster. One was first run in my wide-bed for many years and miles, with a 7.5:1 Cyclone head. That one got its peak HP at 3900 RPM on the dyno, the other has been run at hill-climbs at 4100 RPM, with no problems. The theory is that the bearings ride on a thin film of oil, not directly on the babbitt. Rods do not hold up as well as mains, but are good for many, many miles.
When I had my motor rebuilt some 11,000+ miles ago I also wanted to install a 5.9 High Compression Head on it. When I received the head it was TOO short for my liking (i.e. 1/8" in front and 1/8" in rear) so I returned it and was told I could have another. Well, the NEW? one was the same measurements, so I returned it for a full refund including shipping! Some time later, maybe a year and a half, I ordered another from the same dealer (because of the refund) and this one fit BUT both sides of the head were so badly GOUGED from what I assumed was the grinder they used to remove the slag. I returned it again, and again I received a full refund including shipping. I have to say that I dealt with Synders! I have since ordered numerous small parts from them with no problems.
My QUESTION is has anyone ordered a new head recently and been happy with it (i.e. appearance wise)?
Cast iron shrinkage from molten to solid is roughly 1/8 inch per foot, so what you are seeing is a new cast iron part that used an original part for the pattern.
Terry, I purchased a 6.1 head from Snyders around late September last year. My experience was the front of my head is just under 1/8" short of the block. No problem, as I'm not that finiky. I got what i wanted, and that is PERFORMANCE. Love it. Curious as to why it would be that short.
People should reply with miles they've done not years they've had. 20+ years means little if you only do 200 miles a year on average.
Don't worry about it ...
I installed a Police Head (5.2) in 1963 on an old worn out Model A engine with loose rods (which I pulled shims to tighten up) and drove it 42,000 miles.
Also during this time I used:
1. 8.25 Thomas
2. 6.50 Lion III head
Driven daily from 6,000 to 8000 feet (60 + miles a day) and from 8000 to 12000 feet on weekends. Speed was 50 to 60 MPH. These engines were not "babied".
Engine still runs fine. Just wanted B engine's extra power.
Engine replaced with rebuilt babbitt B block with "C" crank using same head. Have put 20,000 + on that one since that time.
