I am still running a stock head. I'm sure the high compression heads run better, more power, cleaner burning, etc. However that also means more load on the bearings. With a stock oil system (not pressurized), I did not want to add more load to the bearings. Am I wrong? Are you guys with the 5.5 and 6 to 1 heads noticing shorter bearing life or any other related problems?
