help please
cohammer60
Just a few more parts , these are ford pistons that was told were for a model but just not sure.
There are 11 boxes of pistons with pistons marked ford on them but I can't find those numbers on the box online anywhere.
The 01T piston is 1935-42 era, the cylinder heads are also V8 flathead 1939-48 era and also the intake manifold is V8.
that "american bosh" distributor also has the Essex logo on it. id believe that to be off an essex car... I could be completely wrong tho...
the gauge says at the bottom "revs per minute in hundreds" so its an early tachometer for what i dont know.
strange to me to see engine miles and the standard number drum on a tachometer. and why they would label it engine miles. could this be off a stationary generator/engine of some sort? Kind of keeping to a standard of if a car needs lubed every 500 miles so does this and this is the equivalent "miles" its been ran. Much like today on small engines and stationary engines/generators we use an hour meter to regulate when to do service.
Also im not sure why else there would be 2 red lines that id assume would be where you want to keep the needle for optimal HP/torque.
Cool sw tach... At least i think it is a tach...? Ya didnt hit the lotto but dont trash any of it.
I did get a lot of part and want bore you with much more but you never know if you don't ask.
