I have 6 volts @ both sides of the fuse block, both sides of junction box, and 6 volts @ both sides of the coil. I did as Mike V. suggested, opened the points with a piece of paper, removed the condenser and turned the ignition on and I have 6 volts @ the points. Next step from Mike V.
Remove the paper from the points and see that the points are closed. You should not have 0 volts at the points. If not,
The points are dirty or the distributor is not grounded well to the engine.
How do I know the points are closed? I shouldn't have 0 volts. What should I have?
Chris
