KULTULZ
We have a new development! One of our mechanics realized that the C1TE-C rods DID NOT come out of the Sunliner, they came out of our 57 Skyliner with a 292. We went back to the parts shelves and he located the rods that he actually pulled out of the Sunliner. Lo and behold, they are EDC-6205-As, the correct rods for a 352/360.
The rods are unique to the 352/360HP.
Would I re-assemble the engine correctly? If I had the means. The car does sound correct and the correct engine assembly would make it more valuable IMO unless one was willing to pass it off as something it is not.
KULTULZ, I located a chat board from 2013 in which you participated. There was a guy there that tore down his 352/360 and took pictures of everything. It was awesome! The good news is that our heads and blocks had the same casting numbers. The next thing that I am going to do is look for that "HP" that is on the block that we didn't know to look for (and that you showed me). I"m not sure if that indicates the 360HP engine or not. As stated previously, I have always read that there were no numbers on the block indicating that engine, and this is why it could be readily faked.
Can you post that URL you came across?
As for the stamping(s), there had to be a method of FOMOCO being able to identify the assembly for warranty claims/correct service parts replacement.
How about the wheels and brakes, the 3/8" fuel line? Electric wipers? It needs to be gone over with a fine tooth comb to realize it possible full value.
I am going to refer you to another forum where the knowledge these guys possess and trade is unbelievable. They can even tell you what shift the components were made and whether the worker had sex the night before.
Now that does not give you permission to not keep this board updated. If you do start a thread there, please show the URL here so we can keep up...
- https://www.fordfe.com/332-428-ford-fe-engine-forum-f74182/
- http://fepower.net/simplemachinesforum/index.php?board=2.0
