700rpm
Some previous owner installed a helicoil for one head stud (#2) in such a way that that stud is off vertical by about 4 degrees. Can I remove the old helicoil (if so, how?) and install one correctly, or, as I suspect, was the hole drilled off kilter and replacing the helicoil would have no effect?
Or, is it just a bigger hammer problem?
Should I install the stud and attempt to coax it back to vertical, either by torqueing it or by rapping it with a hammer? I don't like these options, but what's a guy to do?
