I have a 1973 302. I am upgrading it to a 4 bbl carb and a HEI Distributor.
Everything has gone smoothly until I dropped in the HEI Distributor. It does not sit flush on the block. It is maybe 3/16" up. The original sits flush. I did measurements with a caliper and ruler on the shafts of the old and new. The old shaft is about 1/16" longer then the new shaft. The shaft from the bottom of the helical gear is .04" longer on the new shaft then the new. I don't know if this is any critical difference or not. Yes/no?
I do see a difference if you look into the bottom of the shafts up. Both are hexagonal to fit over the oil pump shaft. The oil pump shaft is hexagonal with a pin on top. Hard to see but maybe the pin is 1/2' long. I do not understand it's function.
So I have not tried to turn over the engine with the starter. I could tighten down the new distributor with a longer bolt and turn over the engine but if it is not seated correctly I may snap something.
I am going to turn the engine back and forth a few degrees with a breaker bar. Maybe the new distributor will seat down all the way.
The new HEI is from Amazon and there is no name on it. I may return it and spend more money on a name brand with customer support.
Any help is greatly appreciated. Thanks
