djpink1947
I have a 55 ford with the 6volt electrical system still in tack. I recently put in a new dimmer switch because one night I turned on my headlights and had none. But, a quick flick of the dimmer switch and I had high beams. So, I found a new dimmer switch on e-bay and installed it. Right before I buttoned everything up I tested the switch. Low and behold I had low beams. Well this morning I took the car to get a newspaper turned on my headlights and they disappeared. I flicked on my high beams and I was right back where I was before. I took a look at the dimmer switch and tested the connections one connector must be the main juice and each side connectors must be either low beams and high beams. Everytime I flicked the dimmer switch to the low beam side it checked out to be getting current but, not lighting the headlights. I flicked on the high beams and I knew I was getting current to that side because the high beams were on and I could see them on. Also my parking light won't stay on they start to flicker a few minutes after being turned on. My question is: Is my headlight switch bad?? If I replace the headlight switch will I have to replace the dimmer switch also, or will it come back and work?..................Dave
