Alaska Mike
Loosen all the head bolts about an 1/8 to 1/4 inch and start it. Spark plug fires, the head pops up, and engine stops.
I saw your write up when you posted it and made one to remove my stuck head. I used a 3/8" plate rather than the 1/2" plate,(just happened to have the 3/8"plate). It worked great. I think I have about 25 bucks in the puller.
Had 2 old plugs, 2, 1/2" X 6" Bolts, bought the rest of the bolts and nuts from
Lowes.
I'm building a clone of one these pullers. How do I break the porcelain out of the old plugs? It was easy enough to break off the top but no go on the remaining piece inside. I've tried a punch and BF hammer and it doesn't budge.
I just made one of these pullers last year. I did not have any junk spark plugs so I purchased these engine eye bolts from Brattons. Remove the eye bolt and put a hex head bolt in its place.
A video I found helpful was this one: Ford Model A Cylinder Head Puller Tool. He puts spacers between the head and the puller to keep them parallel and to avoid it getting cockeyed and binding. It also makes it easier to place the puller on the head.
I too tapped the holes in the plate which makes it much easier than trying to hold the nut under the plate.
hold engine with eye bolts drive thin putty knife in corners of head works for me every time
I built a "killer puller" some years ago it has featured on the "barn" .Uses all 4 plug holes and pushes off ALL head studs including the front water outlet pair 1/2" thick plate .I will get my computer savvy son to post a pic .
john in Suffolk County England .
