1942 Merc 239, 29A heads, assembling with Best composition head gaskets. There is a V shaped notch in one end of each gasket. Is this to indicate orientation? Notch to front or rear? The only thing I see that would indicate that they may be directional is that the two cooling hole openings at the bottom between the pairs of pistons is not the same size. Thanks, --
Bob
Bob
