The modern zerks from Bratton are too large for the holes in the shackle. I've decided to just reinstall the orig fittings. I'll use the grease gun nozzle fittings from Bratton to lube the orig, then change the fitting for modern. Nothing should have been this difficult if only the things from Bratton would only work. Consider this issue done and over.
