Thanks guys. How many digits is the vin stamped on the frame?
Glad you found it, by any chance does it match the motor? If not it means nothing as many did not right from the factory, but if it does, then you know that you have an original matched chassis, complete, which is pretty high up on the cool scale to me. And if it doesn't it still could be all original, it's just cool to have matching numbers.
I didn't break the pulley, but I think that someone tried to remove the bolt by blocking the pulley with something to turn the bolt, and that's how it was broken.
My question is how to block the engine so that the bolt can be turned. Is there a tool or something easily accessible that can be placed in the flywheel teeth? Or is there another way that I'm not thinking of?
Thanks again.
