31 Model A
Anyone have something that works for them? Sarah has a few scratches on her back window from something scrapping ice off, it seems and the windshield has some wiper scratches.
Ed
Ed
add new glass to your bucket list
ditto the rubbing compound,with the finest steel wool you can find.i would test on rear window or old auto glass for a test. tom
Never did it but I hear that toothpaste is a good compound for removing minor glass scratches. It's a low abrasive. With that said I would think rubbing compound would probably work just as well.
The list is long enough as it is..............![]()
Maybe another bucket![]()
I've always been told if run your finger nail over the scratches and you can feel the scratch nothing but replacement is going to work,
Whatever you do DONT try to fix the ones directly in front of you in the drivers seat UNTILL you find a product/method to repair them.... just in case whatever method you try backfires and causes more scratches or hazyness you can still see out of your windshield.![]()
I have a plastic quart container of 3M liquid polishing compound. This is much less abrasive than rubbing compound. I can't find it right now to give you the part number, but it's a white liquid. I would start with the least abrasive first, so you don't add to the problem.
I've also seen things advertised to make scratches disappear, but I don't know the name. You might call some body shops and glass shops to ask them for advice.
I believe my polishing compound was intended mainly for paint, but I use it for a lot of things. The glass compound you show looks like an even better choice over my compound.
BTW, years ago I quit using those plastic ice scrapers with the brass blade because they leave brass lines in the glass that aren't too fun to remove.
31 Model A: I have had great success with Jeweler's Rouge.......I suggest you "Google" it. It is not expensive, applies easily and has quickly removed minor scratches (to include the dreaded wiper scrape) for me.
