I lost a pulley on a V 12 Lincoln on first start up. Fortunately it did not damage the radiator. True the forward motion of the belt tries to tighten the pulley on the generator, but on coast down, the reverse is true. There should be a clip in the groove on the end of the shaft.I have one that does not have a snap ring.
I put the pulley on before the generator was assembled. I held the armature in a vise with two pieces of soft wood to protect it and put the pulley on using a chain wrench. A strap wrench would probably be better but I don't have one.
You don't have to go mad at tightening it, the load is always trying to tighten rather than loosen it.
Plus the screw on type don't have a fan on. Or at least the ones I have had do not.
Mart.
Mart.
