If you have two wires coming out of the genrator then you have a post Model A generator. One wire is the field ground wire and gets mounted under the cutout mounting screw. The other wire is the output wire and goes to the input side of the cutout.
Thanks Tom does it matter which wire I ground
thanks allenI can get a picture of it this afternoon. I have the same generator on my car, and I also have the diode cutout. The car isn't at my house and I won't be going to work on it until 1 or 2ish eastern time.
