Tom Wesenberg
I'd forgotten that you have an odd end plate. Notice that the adjustable brush is close to the GROUND brush in the first picture you post a link to in #17. As you move the adjustable brush AWAY from the ground brush the output should increase.
So, looking at the generator from the front (pulley end) you will have to rotate the adjustable brush counter clockwise to increase the output. This is opposite the direction you move the standard Model A generator adjustable brush to increase the output.
Is the armature VERY near to the field poles? It's very important that there is very little air space between them. If someone turned the armature to get rid of rust then they have ruined that part. How did you install the poles and get them REAL TIGHT?
