29Cabriolet
Stan,
When building a house you have to start with a good foundation. Where did you come up with the Vinegar? Take the tank to a radiator shop and have them boil it. You need to get all that crud and rust out of the inside of the tank. Including the old sealer. If you don't. You've wasted your time and money. May I suggest you give Bill a call. He'll put you on the correct path.
As for coating all of the inside. That's why I stated about when you think your done you keep on turning the tank around even more. Remember water is the enemy when coating the inside.
And stay away from the additives and other snake oil treatments. The chemicals in some of this stuff will do more harm then good to the sealer.
The vinegar idea was from several fordbarners of an earlier thread when I started the project. As far as a radiator shop, coming up empty on that. At least in my area, the radiator shops that were, are no longer, since at least for modern cars, replacement usually trumps repairs.
