Another young Model A owner and I are having the common gas shut off valve slow leak issue. We both have reproduction gas valves that were lapped with lapping compound and we both use pencil filters. I have a single old brass valve in my loose parts that is probably original. It leaks more than my reproduction valve when tested.
I'm finding that these valves will often leak if any dirt or rust ends up inside them, hence the pencil filter, and the repros leak unless lapped, which we did.
I found one forum that claimed that very few original valves are usable. I'm not aware if that was before or after rebuild.
What are the best replacement options? Is there any particular supplier that has a more reliable valve?
At this point we would both prefer a ball style valve, but it would have to be compatible with the existing fuel lines.
