PepeLoco
What is going on? Got frustrated with what I thought was vapor lock. Come to a light, stop, then try to leave and it's starving for fuel hesitating or dying. When you look you see the inline gas filter empty. Prior to this I would notice air bubbles popping into the gas filter until all the gas was out. Then sometimes it would not fill back up and it would run really rough or die.
So I:
Pulled tank, no obstruction
Acid washed it in/out
Put in tank Screen filter and Electric valve
Clear temporary hose to see what's going on.
Removed inline filter
Gas cap has been off during these test runs
Temp readings on the carb were around 150, +/- 5 degrees f.
Day temp was around 100. Radiator around 150.
Reminds me of how you can hold a full beer bottle, upside down in a glass of beer.
I am thinking of installing a smaller diameter hose to act as a vent.
Is there suppose to be a vent on the top of the carb to the outside? the only one I saw from the inside top was a pin hole going to the fuel inlet. Nope, I did not check to see if that thing was open or plugged. Rats, may have to do that. Would that be the cause?
http://s1229.photobucket.com/albums/ee466/ChrisNoak/?action=view¤t=Gasprobs.mp4
So I:
