PepeLoco
Two suggestions:
1. Check how far the gas line extends past the farrel into the carb. This should only be a short amount, if to far the gas line will butt up against the filter in the carb and restrict your gas flow. You might first simply remove the filter in the carb and see if this helps.
2. Try about 4 oz Marvel Mystrey oil in a tank of gas. I always add it for a fill up. Drove back from Oshkosh in 95-100 degree temps across IL, IN, OH, and PA thru the mountains in western PA with no problems.
Frank, I thought the same thing and took it out long ago in this process.
I thought of the oil too, but we hear of reputable guys say they have never had nor seen vapor lock. This may not be vapor lock and not associated with the heat. I was going to take it for a spin after work and try to quantify the amount of air in that line during different engine and carb temps.
Thanks for the input.
