Why is the rear shimmed? up so high?? Seems to me if the rear was lower it would help with the hood gap without raising the hood lower edge.
Too many issues, ....most notably the frame is sagging. If the front of the cowl goes up any higher to help with the hood alignment, then look at the gap that will be between the lower edge of the hood and the fender. I'd venture a guess the hood clips (latches) are almost fully extended now when latched to the hood.
I'm glad you posted this. I'm having the same issue. Almost no gap in front and a good inch to inch in a half out back. What I did notice on mine is a gap from the rear fender to body where the welting would normally go. I'm planning on removing all fenders and checking wood blocks. I'm curious if there's any deterioration in the front wood blocks or some home made blocks out back.
Without straightening the frame, What have you done ,Mickey Mouse, to make everything fit? Shims, etc.
How is the alignment of the door belt lines??
Paul in CT
