Old Redneck
I just installed a new heater motor and how strong can I use? I have not got my book to tele yet. Slow coming I guess. It had a 8 gauge fuze in line.
Yes,. . . if it's now 12 volts I would use a 15 amp fuse.
Ok that works now with the new heater motor. I have taken the radio out to get to the Dash Light to change the bulb. Still does not work will have to follow the wire to see where it goes. there power in the door button that turn on the dash light. I got both doors open and no light? The radio hot wire was not plug in that was the problem so far with it. however wired this dash should be shot or a swift kick in the rear. This wiring job is shameful I half to say. It will take time but I will straight it out.
Stand by, I'm working on a copy of the map light wiring diagram that I can attach here...... I have taken the radio out to get to the Dash Light to change the bulb. Still does not work will have to follow the wire to see where it goes. there power in the door button that turn on the dash light. I got both doors open and no light? ...
Yes, the dash courtesy light works off of the door switches, and the switch on the fixture itself.The map light should work off the door when open? Now I am guessing. That the only light that it could be. There no other light in the car that I seen.
