Hi drumyn,
Just try to acquire a little Model A faith & follow these simple steps:
All gremlins will immediately leave if you buy something like a yellow analog GE Multimeter with a needle, (as opposed to a digital multimeter), at a place like Wal-Mart, ($13.00 or so), or try Amazon.com.
1. First check voltage at the source, i.e., the battery (+) & (-) terminals with the multimeter.
2. Follow the ground wire to the frame, follow the other hot wire to the starter taking readings along the way of the hot wires which should read the same or almost the same as that voltage read on the battery.
3. If you can follow an electrical wire from its beginning at point A, to its end on point b, just continue to check voltage along the way & at every connection terminal -- it is just that simple -- do not skip one length of wire.
4. Once you get the hang of it, you may find yourself to be fully qualified to teach electrical engineering courses at any university, today that is -- electrical current is really that simple -- almost like water running in a pipe.
5. A Model A electrical diagram indicating wires will surely help.
You are welcome.
