Charlie ny
I'm attempting to get my gas gage reading somewhere near correct.
I purchased a Bob Drake gas tank and sending unit for my '41 1/2 ton.
The truck is now 12volts neg ground and the stock gages are reduced
to 6volts. I have shortened the arm on the sending unit per the instructions.
My dilemma is the gage reads way over full until the arm is 3/4 down.
I called Drake and was told if the arm is shortened per the instructions
everything will work "perfect'. To be absolutely sure I wasn't dreaming
I removed the sending unit and with it wired up I moved the arm and
watched the reading on the gage....same readings as when it was in the
tank. The arm is shortened correctly and Drake says in the catalog the
sender doesn't care whether it's 6 or 12v.
The old beat up sender reads much closer and the dash gage is NOS.
Any ideas out there? Further input from the great northwest would be
appreciated too.
Charlie ny
appreciated too.
Charlie ny
