This is my first run at a flat head- needed to replace fuel pump- While I had it out decided to check the wear on the push rod. Nothing I had read said it would come out in pieces, but it sure did- There was one solid piece machine to insert into a hollow tube at the top, then another machined piece on the bottom (luckly came out with the middle section)- The top also had a small machined sliver about the width of a dime resting on the top, (which incidently is now resting inside my block- Once I get my magnetic retriever I loaned to my neighbor back I can get it out- luckily can still see it)- I am guessing that this rod would have been machined in one piece and what I am dealing with is some idiot's idea of homemade? My apologies if that is the intent, but why not just make a solid rod to the right dimensions? Guessing the sliver was used to extend the rod length to make up for wear. Ideas? I intend to order/ have machined the correct rod.
