Fuel pressure gauge
adileo
39 deluxe, electric fuel pump & dual edelbrok carbs.
Planning on installing a fuel pressure gauge.
Can it go in before mech fuel pump or does have to go in after the fuel pump & right before the carbs?
Thx
The mechanical pump sucks the fuel from the tank, so putting a gauge before the pump will give a negative pressure reading (if the gauge was even capable of reading negative).
So, the answer is after the pump.
Do you just have the mechanical pump there for looks? Also i just put a k&n brand fuel pump on my 48 f1 and it is the only one i found on the market to have an internal regulator so no need for a regulator inline.fyi.
