I had Jim at Enderle Fuel Injection make a batch of these 'poppets' up for me, they are set at 3psi and can shim to 5 or 6psi. They tee into your carb supply and fuel pump supply, when the pressure gets above the poppet value then the excess fuel gets sent back to the inlet of the pump. It is a regulator that looks like normal engine stuff. I had planned to find proper fittings etc to offer as a 'kit' and do a tech article on here to show how it works but haven't found time. They are slick gizmos, if you need one let me know.
