milesoftexas
I have been fighting w/fuel smell & bleeding from carb when hot. Car is hard to start after sitting a while while hot. Runs perfect otherwise. I originally thought about the common problem of our wonderful modern day gasoline boiling out of bowl while hot. Installed heat insulator shield and problem remains. I decided to pull carb, tighten all screws, and reinstall w/ new manifold gasket. While cold and reattaching throttle linkage, noticed gas leaking around throttle lever & shaft area. Pictures are taken after sitting hot for a while. Looks as though gas leaking in this area. Time for rebuild? Any suggestions?
