Yes, if the top plate has radial play then the points gap can change, which also changes the timing. The same goes for a worn shaft or bushings for the shaft.
Often, the post that the moveable point arm pivots on, becomes loose & wobbly, re-tighten the staking on the bottom, with a center punch & a TAP, TAP, TAP!!! Bill W.
