A-Jay
I am thinking of replacing both steering arms, which connect to the Drag link and then the tie rod. Can the tie rod ends be removed from the two round joints of the steering arms without removing backing plate or other things ? Or can I remove the nuts on each steering Arm (left and right side) and then drive out the arms together, with the tie rod still connected to each Arm. Thanks for your advise on this. A-Jay
