FRANK PKNY
I have a newly rebuilt engine, Installed and assembled it as I usually do, with lot of care and precision. Well I think I missed something as I have noticed a slight rumbling from the front crank pully. The nut is tight and locked with red lock-tight. There is some slight play horizontally with the crank it moves back and forth about .005 ". I am aware of the procedure to remove the pulley (one peace). I think I may have left off a washer between the pulley and the nut? Is it normal to have a shim washer here? I don't recall ever having to use one years ago?
