dynaflash_8
So i pulled the drums off my car today to grease the bearings and give it a general once over after a hard trip in the mountains on dirt roads. When i pulled the drums, i noticed that the outter bearing doesnt want to seat all the way on the spidle, and the bearing surface on the spidle looks like someone had taken a center punch to it all the way around. The inner bearing is STUCK. I had to break the rollers out of it, and heat up the bearing red hot to get it to slide off, even then it didnt wanna go. Same story, center punch marks all the way around. What gives and what should i do?
I have another front end with good spindles, but the inner bearings are stuck on that too.
